- Bear Version: 3.00
- OS Version: Mac OS Golden Gate 27.0.1
- What were you doing: I was dictating with Bear
- What feature did you use:
- What happened: Bear became unresponsibve
- What did you expect to happen:
Bear Bug
Date/Time: 2026-09-30 14:19:47.690 -0400
End time: 2026-09-30 14:20:42.071 -0400
OS Version: macOS 27.0.1 (Build 26A434)
Architecture: arm64e
Report Version: 73
Incident Identifier: 943A00E8-A6AC-42A7-A2DF-748CACBA1824
Data Source: Stackshots
Shared Cache: C284A291-B68B-3D0D-A1A0-3F866F87EFDC slid base address 0x195cb0000 (System Primary)
Shared Cache: 7898DD48-6D8C-339E-BCD3-1FE6FBA0B485 slid base address 0x19ea38000 (DriverKit)
Shared Cache: C284A291-B68B-3D0D-A1A0-3F866F87EFDC slid base address 0x19d9d0000
Shared Cache: 16939CFB-CCAD-3A9B-926E-5CC5B2D2CB56 slid base address 0x7ff805058000 (Rosetta)
Shared Cache: C284A291-B68B-3D0D-A1A0-3F866F87EFDC slid base address 0x18b6dc000
Command: Bear
Path: /Applications/Bear.app/Contents/MacOS/Bear
Identifier: net.shinyfrog.bear
Version: 3.0 (14827)
Team ID: 9K33E3U3T4
App Item ID: 1091189122
App External ID: 891716314
Is First Party: No
Beta Identifier: 50DB4462-B84B-5B9D-B10E-292D7B02E63B
Architecture: arm64
Parent: launchd [1]
PID: 1267
Time Since Fork: 50712s
Event: hang
Duration: 54.38s
Duration Sampled: 4.70s (process was unresponsive for 50 seconds before sampling)
Steps: 47 (100ms sampling interval)
Hardware model: Mac16,8
Active cpus: 12
Memory size: 24 GB
HW page size: 16384
VM page size: 16384
Shared cache residency: 14.47% (971.84 MB / 6717.50 MB)
Time Since Boot: 50788s
Time Awake Since Boot: 7960s
Time Since Wake: 2283s
Fan speed: 4439 rpm
Total CPU Time: 11.525s (27.2G cycles, 41.6G instructions, 0.66c/i, 2.36GHz avg)
Advisory levels: Battery → 3, User → 2, ThermalPressure → 0, Combined → 2
Free disk space: 212.38 GB/460.43 GB, low space threshold 3072 MB
Vnodes Available: 73.28% (192857/263168)
Model: com.apple.fm.language.instruct_3b.tokenizer?variant=generic_sparse
Loaded: ??? - N/A, requested by UNKNOWN
Model: com.apple.fm.language.instruct_3b.asr_natural_dictation_speech?language=en
Executing: -9.4s - -9.3s, requested by [1267] use case asr.NaturalDictation
Executing: -8.7s - -8.5s, requested by [1267] use case asr.NaturalDictation
Executing: -8.0s - -7.9s, requested by [1267] use case asr.NaturalDictation
Executing: -7.4s - -7.3s, requested by [1267] use case asr.NaturalDictation
Executing: -6.7s - -6.6s, requested by [1267] use case asr.NaturalDictation
Executing: -6.1s - -6.0s, requested by [1267] use case asr.NaturalDictation
Executing: -5.5s - -5.4s, requested by [1267] use case asr.NaturalDictation
Executing: -4.8s - -4.7s, requested by [1267] use case asr.NaturalDictation
Executing: -4.2s - -4.1s, requested by [1267] use case asr.NaturalDictation
Executing: -3.6s - -3.4s, requested by [1267] use case asr.NaturalDictation
Executing: -2.9s - -2.8s, requested by [1267] use case asr.NaturalDictation
Executing: -2.3s - -2.2s, requested by [1267] use case asr.NaturalDictation
Executing: -1.6s - -1.6s, requested by [1267] use case asr.NaturalDictation
Executing: -1.0s - -0.97s, requested by [1267] use case asr.NaturalDictation
Executing: -0.37s - -0.33s, requested by [1267] use case asr.NaturalDictation
Executing: -0.33s - -0.28s, requested by [1267] use case asr.NaturalDictation
Executing: -0.28s - -0.24s, requested by [1267] use case asr.NaturalDictation
Executing: 0.27s - 0.34s, requested by [1267] use case asr.NaturalDictation
Executing: 0.90s - 0.93s, requested by [1267] use case asr.NaturalDictation
Executing: 1.5s - 1.7s, requested by [1267] use case asr.NaturalDictation
Executing: 2.2s - 2.3s, requested by [1267] use case asr.NaturalDictation
Executing: 2.8s - 2.9s, requested by [1267] use case asr.NaturalDictation
Executing: 3.5s - 3.5s, requested by [1267] use case asr.NaturalDictation
Executing: 4.1s - 4.2s, requested by [1267] use case asr.NaturalDictation
Executing: 4.7s - 4.8s, requested by [1267] use case asr.NaturalDictation
Executing: 5.4s - 5.4s, requested by [1267] use case asr.NaturalDictation
Executing: 6.0s - 6.1s, requested by [1267] use case asr.NaturalDictation
Executing: 6.7s - 6.7s, requested by [1267] use case asr.NaturalDictation
Executing: 7.3s - 7.3s, requested by [1267] use case asr.NaturalDictation
Executing: 7.9s - 8.0s, requested by [1267] use case asr.NaturalDictation
Executing: 8.6s - 8.6s, requested by [1267] use case asr.NaturalDictation
Executing: 9.2s - 9.2s, requested by [1267] use case asr.NaturalDictation
Executing: 9.8s - 9.9s, requested by [1267] use case asr.NaturalDictation
Executing: 10s - 11s, requested by [1267] use case asr.NaturalDictation
Executing: 11s - 11s, requested by [1267] use case asr.NaturalDictation
Executing: 12s - 12s, requested by [1267] use case asr.NaturalDictation
Executing: 13s - 13s, requested by [1267] use case asr.NaturalDictation
Executing: 14s - 14s, requested by [1267] use case asr.NaturalDictation
Executing: 15s - 15s, requested by [1267] use case asr.NaturalDictation
Executing: 16s - 16s, requested by [1267] use case asr.NaturalDictation
Executing: 17s - 17s, requested by [1267] use case asr.NaturalDictation
Executing: 18s - 18s, requested by [1267] use case asr.NaturalDictation
Executing: 19s - 19s, requested by [1267] use case asr.NaturalDictation
Executing: 19s - 20s, requested by [1267] use case asr.NaturalDictation
Executing: 20s - 20s, requested by [1267] use case asr.NaturalDictation
Executing: 21s - 21s, requested by [1267] use case asr.NaturalDictation
Executing: 22s - 22s, requested by [1267] use case asr.NaturalDictation
Executing: 23s - 23s, requested by [1267] use case asr.NaturalDictation
Executing: 24s - 24s, requested by [1267] use case asr.NaturalDictation
Executing: 25s - 25s, requested by [1267] use case asr.NaturalDictation
Executing: 26s - 26s, requested by [1267] use case asr.NaturalDictation
Executing: 26s - 27s, requested by [1267] use case asr.NaturalDictation
Executing: 27s - 27s, requested by [1267] use case asr.NaturalDictation
Executing: 28s - 28s, requested by [1267] use case asr.NaturalDictation
Executing: 28s - 29s, requested by [1267] use case asr.NaturalDictation
Executing: 29s - 29s, requested by [1267] use case asr.NaturalDictation
Executing: 30s - 30s, requested by [1267] use case asr.NaturalDictation
Executing: 31s - 31s, requested by [1267] use case asr.NaturalDictation
Executing: 32s - 32s, requested by [1267] use case asr.NaturalDictation
Executing: 33s - 33s, requested by [1267] use case asr.NaturalDictation
Executing: 34s - 34s, requested by [1267] use case asr.NaturalDictation
Executing: 34s - 35s, requested by [1267] use case asr.NaturalDictation
Executing: 35s - 35s, requested by [1267] use case asr.NaturalDictation
Model: com.apple.fm.language.instruct_3b.asr_natural_dictation_speech?variant=generic_sparse
Loaded: ??? - 40s, requested by UNKNOWN
Model: com.apple.gm.safety_embedding_deny.all
Model: com.apple.gm.safety_deny.input.foundation_models_framework.api
Model: com.apple.fm.language.instruct_3b.base?variant=generic_sparse
Target/responsible processes that have swallowed at least one exception: Bear [1267]
Preferred User Language: en-CA
Country Code: CA
OS Cryptex File Extents: 2
Timeline format: stacks are sorted chronologically
Use -i and -heavy to re-report with count sorting
Heaviest stack for the main thread of the target process:
47 start + 6688 (dyld + 204416) [0x196167e80]
47 NSApplicationMain + 880 (AppKit + 19532) [0x19ab7fc4c]
47 -[NSApplication run] + 396 (AppKit + 182540) [0x19aba790c]
47 -[NSApplication(NSEventRouting) nextEventMatchingMask:untilDate:inMode:dequeue:] + 292 (AppKit + 9114220) [0x19b42c26c]
47 -[NSApplication(NSEventRouting) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 780 (AppKit + 9115464) [0x19b42c748]
47 _DPSNextEvent + 580 (AppKit + 234748) [0x19abb44fc]
47 _DPSBlockUntilNextEventMatchingListInMode + 292 (AppKit + 3654300) [0x19aef729c]
47 _BlockUntilNextEventMatchingListInMode + 48 (HIToolbox + 2364288) [0x1a3bb6380]
47 ReceiveNextEventCommon + 492 (HIToolbox + 780572) [0x1a3a3391c]
47 RunCurrentEventLoopInMode + 320 (HIToolbox + 767376) [0x1a3a30590]
47 _CFRunLoopRunSpecificWithOptions + 536 (CoreFoundation + 1419308) [0x1966d782c]
34 __CFRunLoopRun + 2396 (CoreFoundation + 526332) [0x1965fd7fc]
34 __CFRunLoopDoBlocks + 396 (CoreFoundation + 529392) [0x1965fe3f0]
34 CFRUNLOOP_IS_CALLING_OUT_TO_A_BLOCK + 28 (CoreFoundation + 529584) [0x1965fe4b0]
34 ??? (MenuBarClientCore + 16864) [0x27a57d1e0]
34 ??? (MenuBarClientCore + 130404) [0x27a598d64]
34 ??? (MenuBarClientCore + 130564) [0x27a598e04]
34 ??? (MenuBarClientCore + 132268) [0x27a5994ac]
34 ??? (MenuBarClientCore + 118792) [0x27a596008]
34 -[NSMenuBarItemManagerDelegate menuBarItemManager:triggerActionForItemID:source:completionHandler:] + 192 (AppKit + 11531068) [0x19b67a33c]
34 +[NSMenu(MenuBarAgent) _triggerActionForItemID:source:completionHandler:] + 428 (AppKit + 11518480) [0x19b677210]
34 -[NSCocoaMenuImpl openWithOptions:] + 1076 (AppKit + 9245980) [0x19b44c51c]
34 -[NSMenuTrackingSession startMonitoringEvents:] + 284 (AppKit + 6189584) [0x19b162210]
34 -[NSMenuTrackingSession startRunningMenuEventLoop:] + 344 (AppKit + 6190372) [0x19b162524]
34 -[NSApplication(NSEventRouting) nextEventMatchingMask:untilDate:inMode:dequeue:] + 292 (AppKit + 9114220) [0x19b42c26c]
34 -[NSApplication(NSEventRouting) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 780 (AppKit + 9115464) [0x19b42c748]
34 _DPSNextEvent + 580 (AppKit + 234748) [0x19abb44fc]
34 _DPSBlockUntilNextEventMatchingListInMode + 292 (AppKit + 3654300) [0x19aef729c]
34 _BlockUntilNextEventMatchingListInMode + 48 (HIToolbox + 2364288) [0x1a3bb6380]
34 ReceiveNextEventCommon + 492 (HIToolbox + 780572) [0x1a3a3391c]
34 RunCurrentEventLoopInMode + 320 (HIToolbox + 767376) [0x1a3a30590]
34 _CFRunLoopRunSpecificWithOptions + 536 (CoreFoundation + 1419308) [0x1966d782c]
30 __CFRunLoopRun + 1852 (CoreFoundation + 525788) [0x1965fd5dc]
30 __CFRunLoopDoTimers + 280 (CoreFoundation + 635096) [0x1966180d8]
30 __CFRunLoopDoTimer + 1084 (CoreFoundation + 636360) [0x1966185c8]
30 CFRUNLOOP_IS_CALLING_OUT_TO_A_TIMER_CALLBACK_FUNCTION + 32 (CoreFoundation + 637132) [0x1966188cc]
30 __NSFireDelayedPerform + 376 (Foundation + 496588) [0x197d203cc]
30 -[NSPopupMenuWindow _finishClosing:] + 160 (AppKit + 7100036) [0x19b240684]
30 __41-[NSMenuTrackingSession dismissAnimated:]_block_invoke + 212 (AppKit + 6227760) [0x19b16b730]
30 -[NSMenuTrackingSession _performPreDispatchDismissalActions] + 56 (AppKit + 6227912) [0x19b16b7c8]
30 -[NSMenuBarTrackingSession _tearDownMenuTracking] + 44 (AppKit + 6968944) [0x19b220670]
30 -[NSMenuTrackingSession _tearDownMenuTracking] + 88 (AppKit + 6228588) [0x19b16ba6c]
30 _ReactivateTSMDocumentAfterMenuTracking + 104 (HIToolbox + 1232216) [0x1a3aa1d58]
30 MyActivateTSMDocument + 1848 (HIToolbox + 1231640) [0x1a3aa1b18]
30 utOpenActivateAllSelectedIMInDoc + 204 (HIToolbox + 2552060) [0x1a3be40fc]
30 CFArrayApplyFunction + 72 (CoreFoundation + 262096) [0x1965bcfd0]
30 utOpenActivateAllSelectedIMInDocIterator + 32 (HIToolbox + 1238484) [0x1a3aa35d4]
30 utOpenActivateSelectedInputMethodInDoc + 220 (HIToolbox + 2552672) [0x1a3be4360]
30 ActivateInputMethodInstance + 68 (HIToolbox + 1300520) [0x1a3ab2828]
30 IMKInputSessionActivate + 40 (HIToolbox + 1303724) [0x1a3ab34ac]
30 -[IMKInputSession_Modern activate] + 1748 (HIToolbox + 1662828) [0x1a3b0af6c]
30 -[IMKInputSessionXPCInvocation_Modern invocationAwaitXPCReply] + 120 (HIToolbox + 2689480) [0x1a3c059c8]
30 +[IMKInputSession_Modern withActivity:performActions:] + 196 (HIToolbox + 1660500) [0x1a3b0a654]
30 __62-[IMKInputSessionXPCInvocation_Modern invocationAwaitXPCReply]_block_invoke + 80 (HIToolbox + 1658092) [0x1a3b09cec]
30 -[HIRunLoopSemaphore wait:] + 204 (HIServices + 262180) [0x19db74024]
30 +[HIRunLoopSemaphore _observe:whilePerforming:] + 548 (HIServices + 258976) [0x19db733a0]
30 __27-[HIRunLoopSemaphore wait:]_block_invoke + 116 (HIServices + 262648) [0x19db741f8]
30 -[HIRunLoopSemaphore whileInhibitingCFRunLoopRunFinished:perform:] + 128 (HIServices + 261504) [0x19db73d80]
30 __27-[HIRunLoopSemaphore wait:]_block_invoke_2 + 144 (HIServices + 262804) [0x19db74294]
30 CONSIDER_WHO_REQUESTED_THIS_WAIT_BEFORE_SENDING_BUG_TO_HISERVICES(void () block_pointer) + 24 (HIServices + 262880) [0x19db742e0]
30 __27-[HIRunLoopSemaphore wait:]_block_invoke_3 + 108 (HIServices + 262996) [0x19db74354]
30 -[HIRunLoopSemaphore invokeLoopInModeForDuration:withBlock:] + 248 (HIServices + 367252) [0x19db8da94]
30 -[HIRunLoopSemaphore mediaTime:] + 52 (HIServices + 366968) [0x19db8d978]
30 __60-[HIRunLoopSemaphore invokeLoopInModeForDuration:withBlock:]_block_invoke_2 + 40 (HIServices + 261804) [0x19db73eac]
30 _CFRunLoopRunSpecificWithOptions + 536 (CoreFoundation + 1419308) [0x1966d782c]
30 __CFRunLoopRun + 1172 (CoreFoundation + 525108) [0x1965fd334]
30 __CFRunLoopServiceMachPort + 160 (CoreFoundation + 531180) [0x1965feaec]
30 mach_msg + 24 (libsystem_kernel.dylib + 4012) [0x1964f8fac]
30 mach_msg_overwrite + 480 (libsystem_kernel.dylib + 39464) [0x196501a28]
30 mach_msg2_trap + 8 (libsystem_kernel.dylib + 3104) [0x1964f8c20]
*30 ??? (kernel.release.t6041 + 199048) [0xfffffe000bc94988]
Process: Bear [1267]
UUID: 13410D94-C257-314C-B1FE-9CCFDA61B40F
Team ID: 9K33E3U3T4
Is First Party: No
Architecture: arm64
Parent: launchd [1]
UID: 501
Memory Limit: 0MB
Jetsam Priority: 100
Footprint: 517.47 MB
Pageins: 8 pages
Num samples: 47 (1-47)
CPU Time: 0.109s (318.6M cycles, 270.0M instructions, 1.18c/i, 2.91GHz avg)
Note: Unresponsive for 50 seconds before sampling
Num threads: 22
Note: 10 idle work queue threads omitted
Note: Process has swallowed at least one exception
Note: Workqueue exceeded active constrained thread limit for 47 samples (more dispatch items runnable than allowed to run concurrently)
Thread 0x2cc8 DispatchQueue “com.apple.main-thread”(1) Thread name “(input method 4900 com.apple.inputmethod.ironwood)” (changed) 47 samples (1-47) priority 47 (base 47) cpu time 0.094s (275.3M cycles, 240.6M instructions, 1.14c/i, 2.94GHz avg)
<Thread name unset, process frontmost, thread QoS user interactive (requested user interactive), process unclamped, jetsam priority 100 (requested 100, assertion 0), process memory limit 0MB, process received importance donation from WindowServer [605], process received importance donation from ViewBridgeAuxiliary [1142], process received importance donation from DictationIM [4900], IO tier 0>
47 start + 6688 (dyld + 204416) [0x196167e80] 1-47
47 NSApplicationMain + 880 (AppKit + 19532) [0x19ab7fc4c] 1-47
47 -[NSApplication run] + 396 (AppKit + 182540) [0x19aba790c] 1-47
47 -[NSApplication(NSEventRouting) nextEventMatchingMask:untilDate:inMode:dequeue:] + 292 (AppKit + 9114220) [0x19b42c26c] 1-47
47 -[NSApplication(NSEventRouting) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 780 (AppKit + 9115464) [0x19b42c748] 1-47
47 _DPSNextEvent + 580 (AppKit + 234748) [0x19abb44fc] 1-47
47 _DPSBlockUntilNextEventMatchingListInMode + 292 (AppKit + 3654300) [0x19aef729c] 1-47
47 _BlockUntilNextEventMatchingListInMode + 48 (HIToolbox + 2364288) [0x1a3bb6380] 1-47
47 ReceiveNextEventCommon + 492 (HIToolbox + 780572) [0x1a3a3391c] 1-47
47 RunCurrentEventLoopInMode + 320 (HIToolbox + 767376) [0x1a3a30590] 1-47
47 _CFRunLoopRunSpecificWithOptions + 536 (CoreFoundation + 1419308) [0x1966d782c] 1-47
34 __CFRunLoopRun + 2396 (CoreFoundation + 526332) [0x1965fd7fc] 1-34
34 __CFRunLoopDoBlocks + 396 (CoreFoundation + 529392) [0x1965fe3f0] 1-34
34 CFRUNLOOP_IS_CALLING_OUT_TO_A_BLOCK + 28 (CoreFoundation + 529584) [0x1965fe4b0] 1-34
34 ??? (MenuBarClientCore + 16864) [0x27a57d1e0] 1-34
34 ??? (MenuBarClientCore + 130404) [0x27a598d64] 1-34
34 ??? (MenuBarClientCore + 130564) [0x27a598e04] 1-34
34 ??? (MenuBarClientCore + 132268) [0x27a5994ac] 1-34
34 ??? (MenuBarClientCore + 118792) [0x27a596008] 1-34
34 -[NSMenuBarItemManagerDelegate menuBarItemManager:triggerActionForItemID:source:completionHandler:] + 192 (AppKit + 11531068) [0x19b67a33c] 1-34
34 +[NSMenu(MenuBarAgent) _triggerActionForItemID:source:completionHandler:] + 428 (AppKit + 11518480) [0x19b677210] 1-34
34 -[NSCocoaMenuImpl openWithOptions:] + 1076 (AppKit + 9245980) [0x19b44c51c] 1-34
34 -[NSMenuTrackingSession startMonitoringEvents:] + 284 (AppKit + 6189584) [0x19b162210] 1-34
34 -[NSMenuTrackingSession startRunningMenuEventLoop:] + 344 (AppKit + 6190372) [0x19b162524] 1-34
34 -[NSApplication(NSEventRouting) nextEventMatchingMask:untilDate:inMode:dequeue:] + 292 (AppKit + 9114220) [0x19b42c26c] 1-34
34 -[NSApplication(NSEventRouting) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 780 (AppKit + 9115464) [0x19b42c748] 1-34
34 _DPSNextEvent + 580 (AppKit + 234748) [0x19abb44fc] 1-34
34 _DPSBlockUntilNextEventMatchingListInMode + 292 (AppKit + 3654300) [0x19aef729c] 1-34
34 _BlockUntilNextEventMatchingListInMode + 48 (HIToolbox + 2364288) [0x1a3bb6380] 1-34
34 ReceiveNextEventCommon + 492 (HIToolbox + 780572) [0x1a3a3391c] 1-34
34 RunCurrentEventLoopInMode + 320 (HIToolbox + 767376) [0x1a3a30590] 1-34
34 _CFRunLoopRunSpecificWithOptions + 536 (CoreFoundation + 1419308) [0x1966d782c] 1-34
1 __CFRunLoopRun + 1172 (CoreFoundation + 525108) [0x1965fd334] 1
1 __CFRunLoopServiceMachPort + 160 (CoreFoundation + 531180) [0x1965feaec] 1
1 mach_msg + 24 (libsystem_kernel.dylib + 4012) [0x1964f8fac] 1
1 mach_msg_overwrite + 480 (libsystem_kernel.dylib + 39464) [0x196501a28] 1
1 mach_msg2_trap + 8 (libsystem_kernel.dylib + 3104) [0x1964f8c20] 1
1 ??? (kernel.release.t6041 + 199048) [0xfffffe000bc94988] 1
1 __CFRunLoopRun + 2208 (CoreFoundation + 526144) [0x1965fd740] 2
1 __CFRunLoopDoSource1 + 604 (CoreFoundation + 532040) [0x1965fee48] 2
1 CFRUNLOOP_IS_CALLING_OUT_TO_A_SOURCE1_PERFORM_FUNCTION + 60 (CoreFoundation + 532256) [0x1965fef20] 2
1 __CFMachPortPerform + 288 (CoreFoundation + 709012) [0x19662a194] 2
1 UC::DriverCore::continueProcessing() + 84 (UpdateCycle + 5628) [0x2b5a6e5fc] 2
1 stepTransactionFlush + 588 (AppKit + 5537048) [0x19b0c2d18] 2
1 CA::Transaction::flush_as_runloop_observer(bool) + 140 (QuartzCore + 2294300) [0x1a0eb121c] 2
1 CA::Transaction::flush() + 84 (QuartzCore + 9072) [0x1a0c83370] 2
1 CA::Transaction::commit() + 652 (QuartzCore + 10196) [0x1a0c837d4] 2
1 CA::Context::commit_transaction(CA::Transaction, double, double*) + 1032 (QuartzCore + 2088588) [0x1a0e7ee8c] 2
1 CA::Transaction::run_commit_handlers(CATransactionPhase) + 120 (QuartzCore + 16524) [0x1a0c8508c] 2
1 __39+[_NSCGSTransaction currentTransaction]_block_invoke + 224 (AppKit + 1322056) [0x19acbdc48] 2
1 NSCGSTransactionGetEntanglingHandle + 120 (AppKit + 13115292) [0x19b7fcf9c] 2
1 +[CAFenceHandle newFenceFromDefaultServer] + 60 (QuartzCore + 2799104) [0x1a0f2c600] 2
1 +[CAFenceHandle _newFenceFromServer:] + 84 (QuartzCore + 2797256) [0x1a0f2bec8] 2
1 _CASCreateFencePort + 160 (QuartzCore + 499576) [0x1a0cfaf78] 2
1 mach_msg + 24 (libsystem_kernel.dylib + 4012) [0x1964f8fac] 2
1 mach_msg_overwrite + 480 (libsystem_kernel.dylib + 39464) [0x196501a28] 2
1 mach_msg2_trap + 8 (libsystem_kernel.dylib + 3104) [0x1964f8c20] 2
*1 ??? (kernel.release.t6041 + 199048) [0xfffffe000bc94988] 2
2 __CFRunLoopRun + 1172 (CoreFoundation + 525108) [0x1965fd334] 3-4
2 __CFRunLoopServiceMachPort + 160 (CoreFoundation + 531180) [0x1965feaec] 3-4
2 mach_msg + 24 (libsystem_kernel.dylib + 4012) [0x1964f8fac] 3-4
2 mach_msg_overwrite + 480 (libsystem_kernel.dylib + 39464) [0x196501a28] 3-4
2 mach_msg2_trap + 8 (libsystem_kernel.dylib + 3104) [0x1964f8c20] 3-4
*2 ??? (kernel.release.t6041 + 199048) [0xfffffe000bc94988] 3-4
<Thread name “(input method 4900 com.apple.inputmethod.ironwood)”, process received importance donation from CursorUIViewService [1291]>
30 __CFRunLoopRun + 1852 (CoreFoundation + 525788) [0x1965fd5dc] 5-34
30 __CFRunLoopDoTimers + 280 (CoreFoundation + 635096) [0x1966180d8] 5-34
30 __CFRunLoopDoTimer + 1084 (CoreFoundation + 636360) [0x1966185c8] 5-34
30 CFRUNLOOP_IS_CALLING_OUT_TO_A_TIMER_CALLBACK_FUNCTION + 32 (CoreFoundation + 637132) [0x1966188cc] 5-34
30 __NSFireDelayedPerform + 376 (Foundation + 496588) [0x197d203cc] 5-34
30 -[NSPopupMenuWindow _finishClosing:] + 160 (AppKit + 7100036) [0x19b240684] 5-34
30 __41-[NSMenuTrackingSession dismissAnimated:]_block_invoke + 212 (AppKit + 6227760) [0x19b16b730] 5-34
30 -[NSMenuTrackingSession _performPreDispatchDismissalActions] + 56 (AppKit + 6227912) [0x19b16b7c8] 5-34
30 -[NSMenuBarTrackingSession _tearDownMenuTracking] + 44 (AppKit + 6968944) [0x19b220670] 5-34
30 -[NSMenuTrackingSession _tearDownMenuTracking] + 88 (AppKit + 6228588) [0x19b16ba6c] 5-34
30 _ReactivateTSMDocumentAfterMenuTracking + 104 (HIToolbox + 1232216) [0x1a3aa1d58] 5-34
30 MyActivateTSMDocument + 1848 (HIToolbox + 1231640) [0x1a3aa1b18] 5-34
30 utOpenActivateAllSelectedIMInDoc + 204 (HIToolbox + 2552060) [0x1a3be40fc] 5-34
30 CFArrayApplyFunction + 72 (CoreFoundation + 262096) [0x1965bcfd0] 5-34
30 utOpenActivateAllSelectedIMInDocIterator + 32 (HIToolbox + 1238484) [0x1a3aa35d4] 5-34
30 utOpenActivateSelectedInputMethodInDoc + 220 (HIToolbox + 2552672) [0x1a3be4360] 5-34
30 ActivateInputMethodInstance + 68 (HIToolbox + 1300520) [0x1a3ab2828] 5-34
30 IMKInputSessionActivate + 40 (HIToolbox + 1303724) [0x1a3ab34ac] 5-34
30 -[IMKInputSession_Modern activate] + 1748 (HIToolbox + 1662828) [0x1a3b0af6c] 5-34
30 -[IMKInputSessionXPCInvocation_Modern invocationAwaitXPCReply] + 120 (HIToolbox + 2689480) [0x1a3c059c8] 5-34
30 +[IMKInputSession_Modern withActivity:performActions:] + 196 (HIToolbox + 1660500) [0x1a3b0a654] 5-34
30 __62-[IMKInputSessionXPCInvocation_Modern invocationAwaitXPCReply]_block_invoke + 80 (HIToolbox + 1658092) [0x1a3b09cec] 5-34
30 -[HIRunLoopSemaphore wait:] + 204 (HIServices + 262180) [0x19db74024] 5-34
30 +[HIRunLoopSemaphore _observe:whilePerforming:] + 548 (HIServices + 258976) [0x19db733a0] 5-34
30 __27-[HIRunLoopSemaphore wait:]_block_invoke + 116 (HIServices + 262648) [0x19db741f8] 5-34
30 -[HIRunLoopSemaphore whileInhibitingCFRunLoopRunFinished:perform:] + 128 (HIServices + 261504) [0x19db73d80] 5-34
30 __27-[HIRunLoopSemaphore wait:]_block_invoke_2 + 144 (HIServices + 262804) [0x19db74294] 5-34
30 CONSIDER_WHO_REQUESTED_THIS_WAIT_BEFORE_SENDING_BUG_TO_HISERVICES(void () block_pointer) + 24 (HIServices + 262880) [0x19db742e0] 5-34
30 __27-[HIRunLoopSemaphore wait:]_block_invoke_3 + 108 (HIServices + 262996) [0x19db74354] 5-34
30 -[HIRunLoopSemaphore invokeLoopInModeForDuration:withBlock:] + 248 (HIServices + 367252) [0x19db8da94] 5-34
30 -[HIRunLoopSemaphore mediaTime:] + 52 (HIServices + 366968) [0x19db8d978] 5-34
30 __60-[HIRunLoopSemaphore invokeLoopInModeForDuration:withBlock:]_block_invoke_2 + 40 (HIServices + 261804) [0x19db73eac] 5-34
30 _CFRunLoopRunSpecificWithOptions + 536 (CoreFoundation + 1419308) [0x1966d782c] 5-34
30 __CFRunLoopRun + 1172 (CoreFoundation + 525108) [0x1965fd334] 5-34
30 __CFRunLoopServiceMachPort + 160 (CoreFoundation + 531180) [0x1965feaec] 5-34
30 mach_msg + 24 (libsystem_kernel.dylib + 4012) [0x1964f8fac] 5-34
30 mach_msg_overwrite + 480 (libsystem_kernel.dylib + 39464) [0x196501a28] 5-34
30 mach_msg2_trap + 8 (libsystem_kernel.dylib + 3104) [0x1964f8c20] 5-34
*14 ??? (kernel.release.t6041 + 199048) [0xfffffe000bc94988] 5-18
<process received importance donation from distnoted [915]>
*16 ??? (kernel.release.t6041 + 199048) [0xfffffe000bc94988] 19-34
<Thread name cleared, process dropped importance donation from distnoted [915]>
2 __CFRunLoopRun + 2208 (CoreFoundation + 526144) [0x1965fd740] 35-36
2 __CFRunLoopDoSource1 + 604 (CoreFoundation + 532040) [0x1965fee48] 35-36
2 CFRUNLOOP_IS_CALLING_OUT_TO_A_SOURCE1_PERFORM_FUNCTION + 60 (CoreFoundation + 532256) [0x1965fef20] 35-36
2 _CFMachPortPerform + 288 (CoreFoundation + 709012) [0x19662a194] 35-36
2 UC::DriverCore::continueProcessing() + 84 (UpdateCycle + 5628) [0x2b5a6e5fc] 35-36
2 stepTransactionFlush + 364 (AppKit + 5536824) [0x19b0c2c38] 35-36
2 CA::Display::DisplayLink::dispatch_deferred_display_links(unsigned int) + 364 (QuartzCore + 950296) [0x1a0d69018] 35-36
2 CA::Display::DisplayLink::dispatch_items(unsigned long long, unsigned long long, unsigned long long) + 860 (QuartzCore + 404388) [0x1a0ce3ba4] 35-36
2 CA::Display::DisplayLinkItem::dispatch(CA::SignPost::Interval<(CA::SignPost::CAEventCode)835322056>&) + 64 (QuartzCore + 956840) [0x1a0d6a9a8] 35-36
2 -[_NSDisplayLinkForwarder displayLinkDidFire:] + 216 (AppKit + 12510704) [0x19b7695f0] 35-36
2 __75-[NSScreen(NSDisplayLinkInternal) _displayLinkWithOptions:target:selector:]_block_invoke + 36 (AppKit + 12520004) [0x19b76ba44] 35-36
2 -[NSAnimation _advanceTimeWithDisplayLink:] + 188 (AppKit + 3959956) [0x19af41c94] 35-36
2 NSPerformVisuallyAtomicChange + 128 (AppKit + 502620) [0x19abf5b5c] 35-36
2 __43-[NSAnimation _advanceTimeWithDisplayLink:]_block_invoke + 36 (AppKit + 3960088) [0x19af41d18] 35-36
2 -[_NSFullScreenRevealAnimation setCurrentProgress:] + 140 (AppKit + 7396548) [0x19b288cc4] 35-36
2 -[_NSFullScreenMenuBarCompanionController setMenuBarReveal:toolbarReveal:] + 68 (AppKit + 7398128) [0x19b2892f0] 35-36
2 -[_NSFullScreenMenuBarCompanionController updateContentViewForReveal] + 368 (AppKit + 7399148) [0x19b2896ec] 35-36
2 -[_NSFullScreenSpace alwaysReservesSpaceForMenuBarInFullScreen] + 32 (AppKit + 14155768) [0x19b8faff8] 35-36
2 ??? (AppKit + 16756480) [0x19bb75f00] 35-36
2 ??? (AppKit + 16756364) [0x19bb75e8c] 35-36
2 SLSWindowServerClientGetSpaceNeedsSafeAperture + 240 (SkyLight + 3028452) [0x19d0265e4] 35-36
2 mach_msg + 24 (libsystem_kernel.dylib + 4012) [0x1964f8fac] 35-36
2 mach_msg_overwrite + 480 (libsystem_kernel.dylib + 39464) [0x196501a28] 35-36
2 mach_msg2_trap + 8 (libsystem_kernel.dylib + 3104) [0x1964f8c20] 35-36
*2 ??? (kernel.release.t6041 + 199048) [0xfffffe000bc94988] (blocked by turnstile waiting for WindowServer [605] after 2 hops) 35-36
11 __CFRunLoopRun + 1172 (CoreFoundation + 525108) [0x1965fd334] 37-47
11 __CFRunLoopServiceMachPort + 160 (CoreFoundation + 531180) [0x1965feaec] 37-47
11 mach_msg + 24 (libsystem_kernel.dylib + 4012) [0x1964f8fac] 37-47
11 mach_msg_overwrite + 480 (libsystem_kernel.dylib + 39464) [0x196501a28] 37-47
11 mach_msg2_trap + 8 (libsystem_kernel.dylib + 3104) [0x1964f8c20] 37-47
*11 ??? (kernel.release.t6041 + 199048) [0xfffffe000bc94988] 37-47
Thread 0x370fa 1 sample (4) priority 47 (base 47) cpu time 0.003s (6.6M cycles, 3.1M instructions, 2.10c/i, 2.58GHz avg)
<Thread in another call tree for 3 samples, process frontmost, thread QoS user interactive (requested user interactive, workloop servicer override user interactive), process unclamped, jetsam priority 100 (requested 100, assertion 0), process memory limit 0MB, process received importance donation from WindowServer [605], process received importance donation from ViewBridgeAuxiliary [1142], process received importance donation from DictationIM [4900], IO tier 0>
1 start_wqthread + 8 (libsystem_pthread.dylib + 7392) [0x196538ce0] 4
1 _pthread_wqthread + 360 (libsystem_pthread.dylib + 12256) [0x196539fe0] (running) 4
Thread 0x31f1 Thread name “com.apple.NSEventThread” 47 samples (1-47) priority 47 (base 47) last ran 49.760s ago
<process frontmost, thread QoS user interactive (requested user interactive), process unclamped, jetsam priority 100 (requested 100, assertion 0), process memory limit 0MB, process received importance donation from WindowServer [605], process received importance donation from ViewBridgeAuxiliary [1142], process received importance donation from DictationIM [4900], IO tier 0>
