Can't double click to insert attachments
  • Bear Version: 2.4.4
  • OS Version: 15.5
  • What were you doing: Trying to attach a file
  • What feature did you use: Attaching a file
  • What happened: In the browse dialog, I double clicked on a file. The browse dialog closed, but the file did not get attached.
  • What did you expect to happen: I expected the file to get attached
OK, maybe this isn’t the way it’s supposed to work. I press ⇧+⌘+V to attach a file. I browse to the file. If I click Insert the file gets attached. If I double click on the filename, the dialog box closes and nothing gets attached.
My muscle memory seems to want to double click a file to open/attach it, so I think this is a behavior other apps do. But, feel free to tell me I am wrong.
