Pouvez-vous me dire comment on peut changer un titre en texte normal ?
Merci
You can tap/click on the header icon in the left gutter, select the same header level you want to remove or hit Del with the caret on the left of the first header letter.
Thank you
Do you mean “modify” after clicking on the header in the left gutter ?
So I can’t to it :
-Either I do not see the headers 1 2 3 menu
(“select the same header” …)
I only can put an emoticon in a list.
-Either if I type on the return key and click on the red “done” button it does not work and it vibrates…
Here I’m showcasing what I meant in the previous message:
- Use the header menu to change the header level
- Use the header menu to remove the header style (click/tap on the same level)
- Delete at the left of the header to remove the header style
Thanks a lot
How do you put a picture or a video on a post ?
