- Bear Version: Version 2.10 (14800)
- OS Version: 27.0 (26A428)
- What were you doing: Had done a search and wanted to double click on the text in search to select it.
- What feature did you use: Search
- What happened: Text got selected and at the same time Bear minimised (the functionality I’ve set double clicking on an application’s window to do (default is maximise).
- What did you expect to happen: Text to get selected. Not the Bear window to minimise.
Thanks for reporting this issue.
A fix will be available as soon as possible.
