- Lettera Version: 1.0.0
- macOS Version: 27
- What were you doing: Trying to add an image to a document via drag-and-drop from the Desktop
- What feature did you use:
- What happened: Image got added to the folder as an attatchment (good) but it did not insert in my document.
- What did you expect to happen: For the image to be rendered inside the document as a link.
