First, thank you for Bear 2.8 and 2.9. The MCP server and the tag scoping (Only tags / Exclude tags) changed how I use my notes, and I love that it was done without handing my notes to a third party.
The one thing missing for my workflow is access when my Mac is off. The MCP server runs locally on the Mac, so when I’m out with just my iPhone and ask an AI assistant something about my notes, it can’t reach them.
More and more AI assistants now support remote MCP connectors that work from any device, including their mobile apps: Claude, ChatGPT, Gemini, and agents like Claude Code, Codex and Cursor. Apps like Notion and Craft already offer official remote connectors, but I’d much rather stay with Bear.
Would you consider a remote MCP connector, maybe built on Bear Web, that:
- works with any MCP-compatible assistant (Claude, ChatGPT, Gemini and others) from iPhone, iPad and the web, without a Mac running;
- keeps the same tag scoping (Only tags / Exclude tags);
- lets me choose per connection what the assistant can do, for example read-only, as suggested in Two requests for the Bear MCP server.
Is this something on your roadmap?
I use Bear on a Mac and an iPhone.
