Headings H3 and below have issues in dark mode
  • Lettera Version: 1.0.0 (4458)
  • macOS Version: 27.0.1
  • What were you doing: New file to show issue for this report
  • What feature did you use: ⌘1 etc to format headings with Inspector open
  • What happened: Screenshot below
  • What did you expect to happen: All headings should be white
I just had the reverse happen in light mode but I can’t repro. I was manually switching light/dark mode around the time I noticed so that may help.
Ok, it happened without switching modes so might not be helpful:
@Sadar I had the same issue in Light mode.
I found something that may help you too.
See my response to my own bug report here:
