Bear Version:2.9
OS Version: MacOS 26.5.1
What were you doing: Trying to insert time (hours) via SHIFT CMD 0
What feature did you use: Format Insert date
What happened: It was broken! see image
What did you expect to happen: I expected to see the date:
Below shows the menu shortcut is gone!Any ideas?
Same here. Not sure why this was removed?
In the meantime, you can set the shortcut back via macOS settings:
Thanks for reporting this. I can confirm there’s a bug and we are investigating.
Looks like it was fixed in 2.9.1
