Operation system: Windows
Web Browser: Chrome 148.0.7778.179
What were you doing: Opened the web app
What feature did you use: None
What happened: Tags are missing from the tag list in the left pane
What did you expect to happen: Tags being present
Feedback: I noticed that some tags are missing from the list. The notes containing these tags can be found by searching for them. Clicking on the tag in the notes does not change anything. Nor did logging out and logging back in. Same behavior on other browsers that we never used to access the web app before. Mac and iOS apps are working fine. Apple Advanced Data Protection is OFF.
EDIT : Creating a new note with a missing tag makes said tag reappear in the tag list. This is of course not a viable fix. If I delete the newly-created note the tag will disappear event though there are existing notes containing said tag.
