Rename attachments via MCP/CLI
Hi,
Attachments can be renamed in the app, but the MCP server has no equivalent (or, at least, claude says). It can add (from URL), list and delete attachments, but not rename them.
This makes it impossible to clean up notes programmatically, e.g. fixing generic names like “document (1).pdf” or typos in filenames. The only workaround is deleting and re-adding the file, which needs the original file and an HTTPS URL.
Is it possible to add a rename-attachment tool that also updates the link in the note?
Thanks!
Good suggestion. I will add it to the list of possible additions, and we will have a look at it later.
