Request: Calculations in Bear
I would absolutely love it if Bear was able to perform calculations in a note similar to Soulver or Antinote or you can type expressions and Bear would calculate the answer for you. E.g 2+2=4 or 2*2=4
I note down small little calculations or mini budgets as part of a notein bear all the time so I can see my work, but have to use it calculator to actually do the maths. I don’t wanna have to go to the hassle of opening a spreadsheet app.
Tell me more! Would you like it inline in the text, like Apple Notes, or would you rather have a block of calculations? Can you show some examples of how you are using calculations inside your notes?
Interesting, I could see doing something like Calca. Would be neat, though a bit outside Bear’s main scope/purpose.
not just inline completion, but blocks with multi-line calculations
Here’s an example based on a real note.
+1 for this, inline (similar to apple notes) is good for on tho go calculations for example i write down in my notes the scores for my friends and I Domino game and I add each score to each persons and see it round by round. I could see blocks being really useful if I was making a small idea of a budget or trying to have a specific mini budget for a trip inside the note I also have for that trip.
Another +1. I regularly need to calculate percentages and this would make life so much easier!
Another +1; would be useful to me also
