Suggestion: Mermaid / Diagrams - Export
Lettera Version: Version 1.0.0 (4266)
macOS Version: 27 beta 9
Thank you for implementing diagrams! I would like to ask for an ability to export diagrams as a picture.
What were you doing: Reviewing and sharing complex diagrams created with Mermaid.
What feature did you use: Mermaid diagram implementation.
What happened: Currently, there is no efficient way to export diagrams. To share the logic with colleagues or include it in other documentation format, I have to take manual screenshots, which often result in poor resolution or cropped sections for larger diagrams.
What did you expect to happen: I would like a dedicated export option (e.g., a “Save as Image” button or a right-click menu option) to export the diagram as a high-resolution PNG, JPEG, or SVG file, allowing for a professional and clean way to share Mermaid diagrams outside of the app.
Best Regards,
This is a feature that I’m also really missing!
Until then, CMD + SHIFT + 4 works
only png though.
Hello folks, Mermaid is going to be enhanced in the future (preview/export). I don’t have a timeline yet, but we’ll work on that as soon as we have some time :slight_smile:
