Syncing status for each note
Hi guys,
I’m using Bear Web on Chrome, last version.
I think that the symbol to display the syncing status is useful. That being said, if I’ve understood correctly, that symbol tells the user that “syncing had issues and you might lose the data when closing the window/tab” but it doesn’t tell which note had issues.
In the past I’ve seen that symbol but, since that day I had written a lot of different notes, I didn’t know what to do/which note to back-up before closing the browser.
Could you add a similar “syncing status” icon at a note level?
Thanks!
In this scenario, an indicator of the missing sync status should appear in the bottom left corner of any non-synched note.
Awesome, I didn’t know that this notation would work also in the Web app. Thanks!
