Autocompleted drawn objects move
  • Bear Version: 2.3.11
  • OS Version: 18.3
  • What were you doing:
  • What feature did you use:
  • What happened:
On a side note: Is it possible to get Smart Script within Bear? It is so frustrating that the sketching experience between the notes app and Bear is similar but still very different.
