Bear Custom Formatted Print & PDF - Apple shortcut
Bear Custom Formatted Print - Apple shortcut
Customize Bear print, HTML and PDF production with this Apple Shortcut:
Bear Custom Formatted Print & PDF - v.1.7 - Shortcut
See updated description below!
Bear Custom Print & PDF - Apple shortcut
Updated: Mar 10, 2024 at 10:56 EDT
Customize Bear print, HTML and PDF production with Apple Shortcut
Download and install: Bear Custom Formatted Print & PDF - v.1.7 - Shortcut
User Defined Settings in Style Sheets
3 Sample Sheets are included in Shortcut and can be run as is.
  • Set page size and page numbering.
  • Set page break before heading 1 etc.
  • Set Page break after --- divider.
  • Set custom fonts, sizes or color for text and heading
  • Set center and max-size on images.
  • Using regular CSS style sheets, please add or update samples as needed.
    See section /*** My additions ***/, where you can override Bear’s default export style, using keyword !important; to ensure override “sticks”.
  • Select from multiple CSS style sheets, or run default without prompt (by moving the other sheets to subfolder.)
  • Print or save as PDF from Safari, Edge or Chrome (with page formatting)
  • On iPad/iPhone use preview in Textastic with Safari or Edge to print or share as PDF with images.
The three sample stylesheets are saved to folder: “iCloud/Shortcuts/CSS for Bear Print PDF/”
only first time the shortcut is run!
After that, modify the .CSS files directly in that folder to suit your needs.
If you want to restore the original samples: Temporarily move all files in “iCloud/Shortcuts/CSS for Bear Print PDF/” to a subfolder (so that root is empty of files), and they will be restored on next run :slight_smile:
Page formatting and page nubering is done by included javascript:
https://pagedjs.org/documentation/
/*** Special Section setting: page size, page numbering, ***/
/*** and page breaks; used by included JavaScript ***/
/*** (script added to output file by shortcut) ***/
@media print {
    @page {
        margin-top: 20mm;
        margin-right: 10mm;
        margin-bottom: 20mm;
        margin-left: 10mm;
    @bottom-center {
        content: counter(page);
h1 {break-before: page;}
/* h2 {break-before: page;} */
hr {
    /* Using Bear's --- divider */
    break-after: page;
    visibility: hidden;
NOTE! When Run on iOS/iPad
  1. Install Textastic app to be able to preview, print and make PDFs with images.
  2. Add “/iCloud Drive/Shortcuts/Bear Formatted Print Temp/” as External Folder in Textastic! Only needed to do once.
  3. When Shortcut opens Textastic: Open and preview “Bear Custom Formatted.html” from that external folder.
  4. Tap preview icon to preview and then to view, print and make PDF in Safari or other default browser.
Thanks for this!
I have a question: when using Bear Default Style CSS, anything I type in square brackets starting with a capital letter loses that capitalization.
I.e. [Foo] prints as [foo].
Since I am using square brackets for academic citations, that doesn’t work well since the names of all cited authors are printed in lower case.
How can I change this behavior, please? I am a total CSS noob.
Thank you for your kind attention.
Additional trial and error shows that Bear does this by default when exporting to HTML regardless of whether I use the Shortcut provided here.
Try to escape the [ with \ (back-slash):
\[Foo]
This should solve your issue :slight_smile:
That works, thanks so much!
