Bear Web Clipper Having Trouble with New York Times
  • Bear Version: 2.4.4
  • OS Version: macOS 15.5
  • What were you doing: Trying to clip the following New York Times article: https://www.nytimes.com/2025/05/26/business/electric-vehicles-history.html
  • What feature did you use: “Send to Bear”
  • What happened: Bear does not clip content as it normally does; just attaches HTML file to note rather than capturing full text of article; sometimes it works after many attempts
This has been a problem for at least a year. Not sure if the Times changed the way it renders articles or this is being caused by a Bear update; I suspect the former. Anyway, it was one more reason for me to shift to Readwise for saving articles.
I’ll add that Evernote’s clipper does a fine job not only of rendering New York Times articles but filtering out all the “junk” content.
