Bear Web Update 0.31 (2026-02-13)
Yet another relatively small release where we focused on data stability.
If you have a recent version of the app already loaded in your browser, you should be prompted to refresh shortly; if not, head to Bear Web now to get:
  • fix: ArrowUp from first table cell jumping to last row
  • fix: data loss in some cases when editing a note while the sync is in progress
  • fix: WASM related memory leaks
  • fix: prevent access to browsers that do not support WASM
  • fix: issue with markdown highlight autocompletion
  • improve: exposed some debugging tools to beta releases
