Hey all
I am using the shortcut provided by @kvangork, very much appreciate you sharing it, it works perfectly.
Now, I was wondering what would be the easiest way to add the “pinning” of the daily note, as @bolive is using it, to @kvangork’s shortcut? I am not that shortcut-savvy so I am having a hard time figuring out if I should just use @bolive shortcut and edit it to my needs or stick with the one from @kvangork and add the “pinning” of the daily note, on which I would appreciate some help and guidance.
