- Bear Version: 2.1.9
- OS Version: 14.4.1 Sonoma, iPadOS 17.5
- What were you doing: Creating a link to another Bear Note
- What feature did you use: [[
- What happened: Two notes with the same name appears (there is only one note in my system)
- What did you expect to happen: one note without duplicates
When creating a link to another Bear note on both Mac and iPad using the [[ function, I will occasionally see the same note listed twice. It doesn’t matter which note I select. The created link correctly goes to the right note. This issue usually spans all my devices, but there have been cases where this only shows up on an iPad or Mac.
If I temporally rename the note that I’m linking to, then rename it again, the problem resolves. I’ve applied this solution a number of times, but the problem seems to crop up regularly with other notes.
I’ve attached a few screenshots to document the problem.
- Mac mini. Hero’s Journey is doubled.
- MacBook Air. Hero’s Journey and There Is No Self notes are both doubled, which is an example where the doubling isn’t consistent across devices.
- iPad mini (same as Mac mini).
- Mac mini with two windows showing source and destination note. Clicking either link takes you to the same note.
- Mac mini with two windows after renaming Hero’s Journal to include today’s date.
- Mac mini after restoring Hero’s Journey to original name. Hero’s Journey is no longer duplicated in link window.
Let me know if you have any questions.
