Exiting Code Blocks
  • Lettera Version:Version 1.0.0 (3980)
  • macOS Version: macOS 27 beta 1
  • What were you doing: In a Code Block
  • What feature did you use: Tried to exit code block
  • What happened: Could not exit
  • What did you expect to happen: Should be able to exit easily/
I had entered some text then created a code block as the last line. I had real difficulty exiting the code block and getting to the next line (that does not yet exist)
