Image resizing not working for images where the width was written by desktop Bear to be a floating point value
Operation system: 15.4.1 (24E263)
Web Browser: Chrome 137.0.7141.3
Accessing a note.
Resized images.
In a note, I have a bunch of images, all resized. Some images are correctly sized on the web. Other images are full-sized and have
<!-- {"width":311.99999999999994} -->
after them, which I imagine is supposed to be their size.
Note the underlying .md:
![](image%202.JPG)<!-- {"width":303} --> ![](image%2011.JPG)<!-- {"width":311.99999999999994} -->
The pictures with integer widths display correctly, but it seems like the images with floating-point widths don’t. These images were resized in the desktop Bear client; perhaps it shouldn’t write floating point widths?
So, this is probably two fixes:
  1. Desktop Bear should round image resizes to integers (rather than “x.999999” values)
  2. Web Bear should be OK with floating-point image resizes
Good analysis. 1 is fixed in the last beta already. 2 should probably be implemented as well. I will add it to the list.
