Indentation Issues
Testing version: 2.0 (11015)
What were you doing: writing an ordered list
What feature did you use: ordered list
What happened: after I created a list and wanted to carry on writing normally below it, the text was indented to be aligned with the order list
What did you expect to happen: I expected there to be no indention for the text below the list, and have it return to normal alignment
You have to leave a blank line after a list - it’s in the commonmark standard.
@trix180
i am not sure if maybe the following is a bug
Here the editor doesn’t seem to remove the list indentation until the first character is inserted. I have to check if we can do something.
