roar
November 11, 2021, 12:57am
1
Testing version : 0.1(2510) on iPadOS 15.1 iPadPro 11
What were you doing : tapping goto bottom or top button on extended keypad
What feature did you use : goto bottom or goto top button
What happened : cursor jumped to right position, but screen didn’t scroll
What did you expect to happen : Also scroll to bottom or top
Hi there,
May I ask, was this a once-off occurrence, or has it happened more than once?
Is this still occurring for you?
If so, we’ll investigate further. cc - @matteo
roar
November 18, 2021, 8:10pm
4
Hi @matteo ,
This is an always happening occurrence on Testing version : 0.1(2510) on iPadOS 15.1 iPadPro 11.
Try with the “Welcome.panda” note: cursor does jump to beginning or end of note, but no scrolling happens.
Did a clean install of Panda with iPad reboot, but still same buggy behavior.
If note is kind of short, only when jump to end, the scroll works,
but if note is a few screens long (like “Welcome.panda”) – then no scrolling using those two buttons.
Keep up the good work,
All the best,
Roar
roar
November 19, 2021, 12:40am
5
PS.
Same problem both for iPad and iPhone when using Apple BT keyboard with
shortcuts: ⌘down_arrow / ⌘up_arrow:
Cursor moves to end/top of note, but does NOT scroll!
In Panda on MacOS, these two shortcuts works as intended (with scrolling)
