Math: Formula pasted in callout don't render properly
Pasting a formula in a callout block is misrendered on Bear on macOs (Version 2.5.1 (13605)).
I opened the callout block, typed some text, then opened the math block with the usual $$. Then pasted as plain text the latex code, however this gets rendered as the following:
After some small digging I noticed that pasted text is not prefixed with the angle bracket followed by a space > . And in a separate text editor I was able to fix that by manually prefixing the pasted text, so that it renders as expected.
  > [!NOTE] Functions with this equality are called *analytic*, however this terminology is not important in our case.
  > \begin{align}
- \textcolor{orange}{f(x)}
- \underbrace{ = }_{}
-   \sum_{\textcolor{teal}{k}=0}^{\textcolor{red}{\infty}}{
-     \textcolor{teal}{ \frac{f^{(k)(x_0)}}{k!} }
-     \textcolor{darkgreen}{(x-x_0)^\textcolor{teal}{k}}
- \substack{
-   \text{equality is only true for the functions } \\
-   \text{so-called analytic functions}
- \end{align}
+ > \textcolor{orange}{f(x)}
+ > \underbrace{ = }_{}
+ >   \sum_{\textcolor{teal}{k}=0}^{\textcolor{red}{\infty}}{
+ >     \textcolor{teal}{ \frac{f^{(k)(x_0)}}{k!} }
+ >     \textcolor{darkgreen}{(x-x_0)^\textcolor{teal}{k}}
+ > \substack{
+ >   \text{equality is only true for the functions } \\
+ >   \text{so-called analytic functions}
+ > \end{align}
Proper render:
Also typing $$ in a callout block, actually escapes the first $:
Going on the char we see the backslash :
That is right, pasting inside block quotes and callouts could be smarter, and it is indeed on our long list of improvements we want to do.
I don’t remember the details right now, but this looks like a bug to me. I will investigate.
