Missing visual feedback for copy code button
Operation system: Windows 11
Web Browser: Chrome Version 132.0.6834.111 (Official Build)
What were you doing: Copying a code block
What feature did you use: Copy code block
What happened: The checkmark animation does not play (but the code was copied correctly)
What did you expect to happen: Play the animation
Feedback: The animation only plays if I long press the mouse button on the copy code icon.
Yes, you are right. Thank you for the report.
Fixed. Reload to get the update.
