Active development, looking for feedback before the first stable release.
noxctl is a macOS CLI for declaratively managing Bear Notes structure.
The basic idea:
Write normal notes in Bear, describe the desired structure in
noxctl.toml, preview withplan, apply when the diff looks right.Optionally, you can launch a system daemon, which will constantly regenerate the chosen structure.
It is meant for Bear users who like Bear as the writing app, but want a more structured / Obsidian-like workflow around master notes, hub notes, generated indexes, grouped lists, and backlinks. It manages your notes, moc/hub structures automatically, based on which structure you set in config; notes are auto-appended / auto-sorted by alphabet / auto-formatted to the basic style.
Example of what is formatting looks like:
Repo:
Example:
[meta]
version = "1"
locale = "en"
[[domain]]
tag = "library/books"
index_title = "✱ Books"
blueprint = "flat-list"
Workflow:
noxctl validate ~/.config/noxctl/noxctl.toml
noxctl doctor --config ~/.config/noxctl/noxctl.toml
noxctl plan --config ~/.config/noxctl/noxctl.toml
noxctl apply --config ~/.config/noxctl/noxctl.toml
What it does:
- scans managed Bear tags;
- generates master / hub notes;
- stamps a canonical tag-line onto managed notes;
- keeps generated structure idempotent;
- can run once or as a daemon with a LaunchAgent (launchctl with Go binary).
Important caveats:
- pre-1.0;
- macOS only;
- Bear only;
- terminal-oriented;
- not affiliated with Bear / Shiny Frog;
- not a backup tool;
applymutates your local Bear database through Bear’s bundledbearcli.
So: back up Bear first, start with one small low-risk tag, inspect plan, then apply.
I’m mainly looking for feedback on the README and the user-facing model:
- Is the project understandable from the first page?
- Are the safety warnings clear enough?
- Does
plan → applymake sense for a note app? - Is this useful, or too much machinery for Bear?
Any feedback from Bear power users would be very useful. The project is in pre-alpha stage and mostly scratches my own itches, but if it engages with the community, it could be developed into something interesting. I have more ideas.
