Tabbing breaks table UI
Operation system: macOS Seqoia 15.4.1 (24E263)
Web Browser: LibreWolf 137.0.2-1
What were you doing: Creating a table
What feature did you use: Tabbing to next column in header row
What happened: Table UI was replaced by markdown syntax and added a tab next to the text i was writing
What did you expect to happen: I expected to move to the next header column or create new one
Thanks for reporting!
