Update: better-bear v0.4.0
Update on better-bear since my first post in February. Docs at better-bear.com. It uses the same CloudKit REST API as Bear Web.
What is new
  • MCP server: 22 tools for Claude Desktop (bcli mcp install)
  • Image/file attachments: uploads to iCloud via CloudKit, same flow as Bear Web (#15)
  • Full-text search with date filters (–since yesterday, --since last-week)
  • YAML front matter: create, read, edit — blocks
  • Tag management: add, remove, rename, delete tags across notes
  • Section editing: append after a heading, replace section content
  • Library tools: bcli stats, bcli duplicates, bcli health
  • Archive/unarchive
  • Self-upgrade, one-liner install
  • Locked note detection in search results
Fixes
  • Edits not syncing to Bear desktop. Was missing conflictUniqueIdentifier (#16)
  • Vector clock handling, deleted records during sync, error surfacing
Contributors
Thanks to @program247365, @asabirov, and @darronz for PRs fixing sync issues, adding the project spec, redesigning the auth page, and more.
Issues welcome.
Update. As you can see in the docs, I also added context library features based on Andrej Karpathy’s LLM Knowledge Base pattern (April 2026).
