Window issue when opening .md from Finder
Lettera Version: 1.0 (4091)
macOS Version: 26.5.2
What were you doing: opening a .md file from Finder (double clicking)
I’ve got Lettera set as my default markdown app while I’m testing. I’ve got two monitors, and I generally keep a Finder window open on the secondary display and have Lettera set to always open on the main display (set in Dock).
When I double click to open a .md file, depending on the app state, I’ll get different results, but generally speaking, if there were no windows opened when I quit Lettera, Lettera opens with two windows (as reported in other threads), however, most of the time the document I’m opening will render almost completely outside the main monitor… with only the barest edge of the window showing. I’ve included a screenshot. It doesn’t look like much but the white line is actually the second Lettera window (the note I double clicked on) almost completely off the righthand side of the main monitor.
LetteraWindow
Confirming. Two windows open up when I double click in finder with Lettera as default viewer. A blank one and the other with the document. Single monitor.
