30 Days of Using Bear + Creating Shareable Links With Hermes
Hi Folks,
I recently switched from Evernote to Bear Pro, while I did not need the transcription feature anymore, I really missed the ability to share notes via a link.
So, what I did was:
  • Using Hermes Agent + DeepSeek Flash v4 0731 - built a GitHub workflow through a private repository where the notes can be shared in encrypted format (so only the person with that key in the URL will be able to view it),
I thought it was interesting enough to share it here, you can try it too. All you need to do is grab a token key from GitHub with private repo access, and then you’re good to go.
This is free to do btw - if anyone is unaware of GitHub.
The Bear MCP + my Hermes Agent has helped me achieve it in one hour of free time in a work day. So, yes, the MCP unlocks so much of great stuff.
I’m thinking of sharing more as I build things around it, hope this is useful for some! :slight_smile:
