A few recommendations
  1. I’d love to be able to use a cli to open a md file from my command line (i.e. lta file.md)
  2. the tab bar is a little confusing to look at. I know its convention, but I think tabs should be more visibly differentiated (think like in a code editor). Chrome isn’t great, but it is easy to see that tabs are at the TOP of the window hierarchy. Also, the navigation sidebar squashes the tab bar, which makes it feel like its not part of the tab content, but somehow outside of it, which doesn’t (to my mind) feel right).
  3. Font configuration - I want to use my preferrred fonts, for both variable width and fixed width text
  4. the code blocks feel like they have too much padding on the top and bottom and not enough on the left/right.
Otherwise this is a nice app!
One more thing: I would like a way to easily view the original raw text content. Yes, I open it in another editor, but at least while I’m testing and comparing layout, It would be helpful to quickly see if there’s an extra new line in the .md doc where there shouldn’t be, etc.
