Ability to link a finder Folder in a bear note
I am aware of the ability to insert a file but was trying to see if there was a way to link a finder folder in a bear note. Personal use case is that I have a Note for a course (MGMT 410) and would like to be able to link the folder for that class in the note if possible.
I have used this to link to Finder objects in Bear notes and it works well enough for my purposes:
Of course, it doesn’t work on iOS or the web version of Bear, so keep that in mind.
This looks awesome! Thank you
I put this shortcut together as a personal interest at sixty-one; it was only meant for me, but you’re welcome to use it as a guide.
This post was translated from Japanese to English using Kagi Translate.
