- Bear Version: 2.3.10
- OS Version: macOS Sequoia 15.2
- What were you doing: Open backlinks panel
- What feature did you use: Backlinks
- What happened:
When opening the backlinks panel, I see the list of documents with the backlinks and all the paragraphs containing the same document title.
This is very noisy, as the backlinks should link just the backlink. See the attached picture (things in the red square should not be there). - What did you expect to happen:
When opening the backlinks panel, I’d expect to see the list of the documents with just the paragraph containing the links.
You should turn off the “Show Unlinked Mentions” toggle, this will only show the actual backlinks you’ve done and not the mentions.
Nice ![]()
Thanks a lot
