Bear no longer works on Big Sur
  • Bear Version: 2.3.3
  • OS Version: 11.7.10
  • What were you doing: Opening Bear after latest update
  • What feature did you use:
  • What happened: Immediately crashes
  • What did you expect to happen: That is would run :slight_smile:
The crash report indicates its attempting to link against a dynamic library that is not available:
Application Specific Information:
dyld: launch, loading dependent libraries
Dyld Error Message:
  dyld: Using shared cache: 3694F5E4-3E85-3CD5-A2B0-534E2DFC1355
Library not loaded: /System/Library/Frameworks/QuickLookUI.framework/Versions/A/QuickLookUI
  Referenced from: /Applications/Bear.app/Contents/MacOS/Bear
  Reason: image not found
Binary Images:
       0x10dbd5000 -        0x10dec4fff +net.shinyfrog.bear (2.3.3 - 12890) <5D03A5B2-3366-35FB-BC44-0038E14236BA> /Applications/Bear.app/Contents/MacOS/Bear
       0x10dfab000 -        0x10e2f1fff +net.shinyfrog.BearCore-Mac (2.3.3 - 12890) <CBB84384-9AFD-3FD2-8123-7C40129C7817> /
I’ve subsequently seen there are some references to this happening for 2.3.2 also, and there being a download provided that bypasses the issue.
Will this be fixed in the App Store version at all?
We are waiting for news on Apple’s side but meanwhile you can use this temporary solution
As I’ve mentioned elsewhere, this version of Bear no longer works for me on Big Sur 11.7.10. The app opens but notes text appears at the bottom of the screen UPSIDE DOWN. Still waiting for some guidance on how to fix this.
And still waiting for news of a fix for this issue - even an update with some kind of ETA would be helpful. Otherwise, I have a subscription for a product I can’t use. Thanks!
Update 2.3.5 is now available on the Mac and iOS stores. You should probably manually update by visiting Bear’s page here
Thanks. That seems to have fixed if for me.
