- Bear Version: Bear Web beta /v0.1.21/favicon.ico
- OS Version: Windows and MacOS, Edge and FireFox
- What were you doing: Testing Search Replace in note
- What feature did you use: Cmd/Ctrl+F for Search Replace
- What happened: For every character you type in replace field, insert point (cursor) jumps up to Search field, and makes it very hard to type anything in replace (without also messing up search term)
- What did you expect to happen: Cursor to stay in Replace field while typing.
Otherwise search replace works very well, and Bear web beta is already fabolous even as a beta.
Will report some more issues later …
