- Bear Version: 2.4.3
- OS Version: 18.4.2
- What were you doing: find and replace
- What feature did you use: find and replace
- What happened: after the first replace, the focus for all subsequent matches shifted one place to the right
- What did you expect to happen: the focus to remain on each match as I made changes one by one.
The attached images show the sequence of events. After the first replacement the focus shifts right by one character and I can’t make the second replacement.
