Bear Web Update (2025-03-11)
Today we bring you another update featuring a short list of changes, but with a fairly big impact.
FIXES
  • sidebar tags misbehaving - this should help with missing or misplaced tags in the sidebar, and missing notes
Other
  • Improved cursor up/down movements.
  • Improved cursor movements, including Home/End.
Thanks for the update from March 11, 2025. My duplicate tags are now gone and corrected - much appreciated! However, there’s still an issue with the tag order.
We’re going on vacation in May and June, and I created a tag for each destination, including the date and the days we’ll be there. On my iPhone and iPad, the order appears as follows:
Vacation/2025-05_9-16_Tirol (meaning May 9 to 16, just to clarify)
Vacation/2025-05_16-23_South Tyrol
Vacation/2025-05_23-06_Caorle
However, in Bear Web, the order is different:
It seems that Bear Web treats the number “9” as greater than “16” and “23,” placing this entry at the end.
If I change “9” to “09,” the order is correct again, so that’s a workaround.
I just wanted to report this so you’re aware of it.
Thanks, and keep up the great work!
Nice find! We’ll consider that, but it may be difficult to achieve exactly the same semantic in the browser.
Just for your information: the workaround is perfectly fine for me. However, the order won’t be the same as on the iPhone/iPad without this workaraound. Of course, it could also be “fixed” the other way around by changing the order on the iPhone/iPad to match Bear Web :wink:
It works great for me, I just wanted to mention it in case it might actually bother someone else that it won’t be identical.
