Bear Web Update (2025-04-28)
A new version is waiting for you, just reload https://web.bear.app to get:
  • Improved sync with Cloudkit
  • Improved matching of code block markers to fix regression caused by improved character composition handling.
  • Fixed some edit related shortcuts
  • Fixed inserting of line breaks in code blocks with syntax highlighting.
  • Fixed moving cursor up past a blank line in Firefox.
  • Fixed table side-scrolling to cursor.
Hi thanks for the updates, really appreciate. Especially love that ctrl + backspace is now fixed and now my notes will not be accidentally deleted while editing.
