BIU keyboard does not stay when used in tables
Testing version :
2.1.5 (12531) beta on
iPadOS/iOS 17.4
iPad Pro (11-inch) (2nd generation)
Using BIU keyboard inside table cells
BIU keyboard inside tables
It goes back to ABC after each command of: moving, deleting, adding rows and cells. Or even if you change focus to another cell. Very annoying!
It should stay in BUI mode until I close it with ABC button, like it does when used on normal text.
Not a new bug, have been like this since first 2.0 release
