Testing version: Bear 2.0 (9652), Mac macOS 12.6 (21G115)
What were you doing: trying to link to a heading in another note using the [[note1/someheading]] syntax.
What happened: Bear 2.0 didn’t suggest any headings with the autocomplete tool.
What did you expect to happen: like in Bear 1.0, that Bear 2.0 would suggest the matching headings.
Pics below:
Bear 1.0:
Bear 2.0:
