Now that end-to-end encryption is finally here, I am in the process of migrating from Apple Notes to Bear Notes.
I’m playing around with checklists now, and one feature I would like is, if you check off an item, it should mark all the indented subitems and checked off also. And if I uncheck an item, it should uncheck all the items below it.
