jenxi
1
Testing version: Version 2.0 (10209)
What were you doing: Copying text from a code block and then pasting in a new line.
What feature did you use: Code block
What happened: Some lines copied the code block formatting.
What did you expect to happen: The lines should be text since there is not ``` around them.
I copied the text from within the code block and pasted it below in a new line. The indented lines still show the code block formatting.
roar
2
Hi there,
Tab and 4 spaces are also alternative “standard Markdown” (per line) code block tags.
Example here in Bear Beta forum site with 4 leading spaces
Regular text
Leading Tab as code block line tag
The thing is that Bear 2, unfortunately, doesn’t support nesting in footnotes, like iA Writer for example
That’s how it works in MultiMarkdown editors (iA Writer, nvUltra, etc):
jenxi
4
Yup, Bear 2 doesn’t support it. The note is for Github-flavoured Markdown footnote.
jenxi
5
Ah, right. That makes sense now. Copying and pasting made me overlook that. I kept thinking I was somehow copying the formatting.
