Crashing when toggling fullscreen and sidebars
  • Bear Version: 2.6.3 (13844)
  • OS Version: macOS 26.0.1 (25A362)
  • What were you doing: Reading / Writing
  • What feature did you use: Toggling fullscreen and sidebars (with keyboard shortcuts, but the bug also occurs when using the mouse)
  • What happened: When toggling fullscreen and the sidebars most of the time Bear crashes (sometimes the sidebars UI looks broken)
  • What did you expect to happen: Toggling fullscreen and sidebars should not crash Bear.
Mostly the crash happens shortly after toggling fullscreen and then toggling the sidebars.
I have the same problem. At fullscreen, after toggling sidebar, bear is crashed.
I am not experiencing the same issue. I am running on a Samsung Chromebook - Version 143.0.7499.46. I should also clarify, I am using Bear Web, not an app.
Thanks for reporting this. We’ll provide a fix for this issue with the next Bear update.
