- Bear Version: 2.6.4
- OS Version: MacOS 15.6.1
- What were you doing: Creating code blocks
- What feature did you use: Automatic code blocks
- What happened: Creating code block after a bulleted list indents the second ``` causing the code block to not syntax highlight
- What did you expect to happen: the second ``` should not be indented
Thanks for reporting. As a workaround until fixed, have a blank line between the list and code blocks.
