- Bear Version: v2.3.11 (13182)
- OS Version: 15.3
- What were you doing: creating an ordered list where an entry contains a code block and then a nested unordered list
- What feature did you use: Ordered List, Unordered List, Code Block
- What happened: the unordered list will not indent under the code block
- What did you expect to happen: unordered list able to be indented under code block
The below screenshot shows the situation in Bear, with a code block below it for the markdown.
1. This is an ordered list
\```md
This is some code
- example
2. This is the second point of an ordered list
Edited – escape code block in code block
