Hello! Newer Bear user here. Just started to try and edit notes on my phone, i typically use my laptop for this. I can’t find a way to stop this from happening. When I click a note my cursor will jump to the top. Tried to get a video but it might be a bit fuzzy due to the upload restrictions. Appreciate any help!
I’m on the most up to date version of the application and iOS.
Hey there!
I’m currently investigating the issue, but, unfortunately, I’m not able to reproduce it.
May I ask you if it still continues to happen if you close Bear (Close an app on your iPhone or iPod touch - Apple Support) and open it again?
Hey! Thanks for getting back. I actually just ended up finishing my notes on my laptop because of that and didn’t try again until this morning with the Bear application. I did restart my phone and uninstall the application and reinstalled. It seems now the cursor is acting as intended with no issues.
The phone application is really awesome. Super impressed actually!
Thanks again, I guess you can probably close this as a user error or phone issue. Thanks again for taking the time.
Thank you for the information!
For now, I will close the issue, but please, if it happens again, write directly to me with the information about what you were doing before it happened (e.g., "editing a table”, “jumping across notes with the history navigation”, “writing with an external Bluetooth keyboard attached”, etc.). In that case, it would also help to know if restarting Bear would fix it.
Thank you so much! I’m glad you like the phone version!
Have a fabulous day!
