Encrypted Note Backups Contain Unencrypted Content
When you export a full backup, and you have notes that are encrypted, and those notes contain PDF’s, the words of those PDF’s are unencrypted in the text bundle file info.json
Example below:
Either search text content should be encrypted, or, sufficient warning should be given that this type of content is not encrypted.
Hello @HumbleBear!
The searchText is indeed removed from the file on encryption, but it seems like it is added again when a later OCR happens. We will be fixing this in the next update.
Thank you so much for reporting this!
No worries at all - thanks for the impending fix :slight_smile:
