On iOS. Details in headline.
Hello and thanks for reporting this issue.
Can you please make a quick video of this issue?
So apparently the issue happens whenever clicking the BIU button. It returns the cursor to the header
making it really unusable.
It’s apparently not limited to bullet point situation.
This is odd. Can you please tell me the iOS and Bear release you are currently using?
iOS 18.0.1 and Bear 2.3.4
Can you please try to update to Bear 2.3.5 first and then iOS 18.1 if the problem persists?
Regarding Bear, you might need to update manually by visiting its App Store page:
Updating to newest version of Bear fixed the issue (tested Bear before I updated to newest version of iOS).
