Testing version: 2.0.5(11799)
What were you doing: Anything, Anytime, Anywhere
What feature did you use: Click text for cursoring
What happened: cursoring not working
What did you expect to happen: cursor moved to clicked position
That looks much more like a system/mouse issue than a bear issue. Have you narrowed it down to only being when you’re focused on bear?
Can you please tell me the macOS release you are running?
Yes. It occures only on Bear.
Right, macOS Monterey.
