Inconsistent cursor icons
  • Bear Version: 2.2.2
  • OS Version: 17.5.1
  • What were you doing: Hovering over and/or using the new side toggles + code copy
  • What feature did you use: Just hovering or clicking
  • What happened: Unlike other interface elements, the mouse cursor doesn’t appear to sticky to the buttons, or to conform to shape highlights like other elements do
  • What did you expect to happen: Sticky to interface elements, and change/conform shape to the buttons
Video of the issue, with a comparison to a couple of minor UI elements that do behave as I’d expect:
Hey! Good catch! Thank you for reporting this, we will fix it asap! :raised_hands:
